Sony Little Big Planet Logo
Posted on Dec 14, 2009
I HAVE 1 CONTROLLER AND 2 PLAYERS APPEAR IN THE SCREEN. CANNOT ERASE THE 2ND PLAYER
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 18, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
122
Points
Get one other controler sighn in and then sighn out
Ipod 2 gig 2nd Gen. wont show up on computer or itunes
Have you ever tried to restore it into factory settings?
Be careful, by doing so will erase all your data on it. But don't worry, you can recover music from ipod after restore it into factory settings.
I have a Samsung BD-C7500 blu ray dvd player with USA region setting and need to change/convert to Australia region setting... Is this possible?
The details below only work for the DVD Region (dependant on your Firmware) and not the Blu Ray.
1. Ensure that there is no disk in the tray.
2. Switch the player on.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller - and enter the players region code from below on the number pad.
5. The the players region code should appear at the top left corner of the screen.
6. Quickly enter a "9" to make the player region free. (Just try pressing 9 on the remote controller until you see 9 appear in the upper left corner of your TV screen.)
7. Open and close the disc tray. Power down and power up again.
All region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
How do I connect the 2nd wii controller for donkey kong country returns? It does not allow the 2nd controller (two players) to play the game
First, make sure the 2nd controller is paired with your Wii. Then make sure you're in 2 player or co-op mode. I think when I played it all we had to do was turn on a 2nd controller and Donkey Kong automatically added the 2nd player in.
My freestyle player says format error how to fix?? it was working fine and then this error.
Hello there,
Q.: My player is having a DRM error / Format Error / Empty Disk Error
what do I do?
A: For all 3 errors, the first step is to attempt to reset the player, this can be accomplished by pressing the play and menu
buttons down together for approximately five seconds. If reset does nothing, make sure all the songs are .mp3s, if all songs
are .mp3s, attempt to format and re-sync the player.
if you need it
How do I convert my iTunes into MP3 format?
A: See Music Conversion Instruction Document: Transferring and Playing Music on Freestyle Audio mp3 players with
iTunes.
if you need to format the player here is how for MAC and windows.
Q.: What's Reformatting, How do I format my Player?
A: Reformatting your player basically wipes you player clean and deletes all songs, leaving you with a blank slate. Like
most removable drives you can reformat your player with no worries of damage to the unit. When reformatting on a Mac
make sure you choose the MS-DOS format style.
(CAUTION: FORMATTING WILL ERASE EVERTHING ON THE DRIVE)
PC (Windows NT, 9x, XP and Vista):
1. Plug in the Mp3 Player.
2. Put the Player in removable drive mode. Under "My Computer" you should
see the player as a removable drive.
3. Right click on the "removable drive" and a Drop down menu should appear.
4. In the menu select the option "format..."
5. Make sure that "FAT" is selected as the file system and that Allocation
Unit size is set to "Default Allocation Unit Size"
6. Now click format and wait, after it says format complete, you're done.
MAC OS 9 (and Earlier):
1. Plug the player in.
2. Put the player in removable drive mode.
3. Single-click the disk's icon on your desktop to format.
4. Pull down the "Special" menu from the top of the screen and select "Erase
Disk..."
5. Enter whatever name you want in the "Name:" field in the window that pops
up. If the disk is a hard drive, select "Mac OS Extended" from the
"Format:" pull down. If the disk is not a hard drive (such as a Zip Disk
or other removable media), select "MS-DOS or MAC OS Standard" for the
format.
6. Press "Erase." The drive will be formatted and ready to use.
MAC OS X (and later):
1. Start your computer and plug in the player in the USB port after the Mac
OS has completed loading.
3. An icon for a removable drive should appear for the flash drive on the
desktop.
4. From the Dock, open "Disk Utility".
5. Click "Erase" from the top selector (next to "First Aid")
6. Choose "MS DOS File System (FAT16)"
7. Click the "Erase" button
8. Perform the instructions given on the screen and finish the formatting.
if you need any help with a Step let me know and i hope this information was helpful don't forget to Rate .
My samsung bd-c7500 dont play other dvd region than 3..i would like to unlock the dvd region to multi-region..how can i do that?
hi,
try the following
As I live in Kazakhstan my BD-C7500 is locked to DVD region 5. Just use the codes at the end of this tutorial for your own DVD region.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller - and enter 5 6 7 3 2 on the number pad.
5. The region code "3" should appear at the top left corner of the screen.
13. Play a foreign DVD to verify the change.
For people from other parts of the world, all region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
ok
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    1helpful
    SNES Controller 2 Port Not Working
    The 2nd Player controller port just might be shot. That or the part of the main board that deals with the 2nd controller. My suggestion is purchasing another controller board (the main board and controller board are separate and easily removable pieces) and switching them out. If the problem persists then the SNES's main board probably has an issue.
    Erase pictures
    if you have the cable for your player i suggest to connect the Mp3 to your computer and wait until your folder will appear.
    their you can select and see the pictures you want to delete..
    thanks,
    2answers
    I can't figure out how to set up the 2nd controller so I can play multiplayer.
    you have to turn the controler on and choose the second players acount. turn on solo mode and let player 2 press start.
    Nascar 08 can't play 2 players
    having tried different controllers and still the same have you tried the game in another playstaion see if the game at fault or the console .also you might find here helpfull as well .
    http://forums.ea.com/mboards/category.jspa?sls=2&categoryID=66
    riz.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
