Coleman Powermate Powermate 5000W Generator Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the oil drain plug for a briggs and stratton 11 hp engine?
  • aaron12274 Dec 14, 2009
    I couldn't find the model of the generator I have which does have a briggs 11hp engine. was hoping someone could answer me based on the engine and not the model of generator.
Anonymous
Level 2:
New Friend:
  • Expert 160 Answers
  • Posted on Dec 14, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
160
Questions
0
Helped
65005
Points
350
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
  • Anonymous Dec 15, 2009
    ASSUMING U LOOKED ALL OVER FOR A DRAIN PLUG AND DIDN'T FIND ONE, WE CAN ASSUME B&G HAS MADE ENGINES IN THE PAST WITHOUT DRAIN PLUGS. UR PROBABLY GONNA HAVE TO PUMP OUT THE OIL FROM THE OIL FILL.
Where is the oil drain plug on a 20 HP Briggs & Stratton mower engine?
Many engines today either have no drain, or a drain that you cannot get to because of the way the engine is fitted, just buy a syringe to suck the oil out, there are plenty available made to do just this job.
Oil drain plug for 7.5hp briggs straton engine
If you're looking to obtain an oil drain plug -- your post doesn't actually say that -- I'd recommend your local hardware or plumbing or home improvement store. Briggs & Stratton generally uses standard iron pipe threading on their oil sump drains. You'll want a 3/8" IPT plug.
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Wheres oil drain on 21 hp intek briggs
you should have a square plug on the side of the block usually on the starter side of engine
WHERE IS THE OIL DRAIN PLUG 0N 22 HP INTEC
Here is a link showing you parts layout that includes the location of the oil drain plug:
Page 8 discusses changing the oil
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=ioswDLJU0HtjhJvcv4
I hope this helps,
Magoo
5helpful
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
