Yes. FEATURE 70 will transfer a call. You can either do it by hand, or program a button (FEATURE *3 button FEATURE 70) to do it.
Carl
Here is the manual that shows how to transfer calls to an internal extension. It should work.
http://www.sjgl.co.uk/sjg-bcm-user-guide/7208-terminal-user-guide.htm
If not, then you can program a feature button yourself, see here:
http://www.phonserv.com/meridian_norstar_programming.htm
Good Luck
SOURCE: Trying to switch the extension number.
On the newer norstar systems the T7208 and lower phones can not be used for programming.The T7316e phone has to be used for programming therefore feature 983 will only work on the T7316e set.To change local dn's you have to go into config programming and to change dn old dn then new dn.
