Nikon D60 Digital Camera Logo
Anonymous Posted on Dec 14, 2009
Nikon d60 - error. turn camera off and on again.
Nikon d60 - ''error. turn camera off and on again.''
i've turned camera off and on.
i've removed battery and put back in, and same with the sd card.
the camera was working just fine before this happened.
i can't find any info on this type of error...any ideas???
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1284
Points
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
*Error. Press shutter release button again. Nikon-D60
Your camera error is mostly like motor (aperture control unit) failing cause 90%, or 10% would be actually shutter unit defective.
I've used the Quantaray PZ-1 DSZ on my Nikon N80 film camera and had no problems. I would like to use it on my digital Nikon D60.
There is no problem with the trigger voltage, which I assume is your primary concern. You may not get all of the features you would with a Nikon flash, but you should be able to use it with the D60 just as you use it with the N80.
I have a nikon d60 and every time i turn it on a message comes up saying "error. turn camera off and then on again." i do this and the same message comes up. how can i fix it ?
Try to take out the battery and then put it back after a minute or so. If the camera is still not coming to, change the battery to another one. If this does not work, you need to take to the camera to a repair shop to be checked.
Error in display
Press the shutter release again. Take out the battery and put it back in a while (1-2 min). Reset the camera with the reset button.
If this doesn't work, take it to the Nikon repair.
Turn on 'more' my Nikon D60, power fails. What to do?
CHECK ON NIKON WEB SITE
MAY HAVE A FAULTS PAGE ON IT.
GOOGLE..TURN ON NIKON D60 POWER FAILS
Nikon D60 "Press shutter release button again". Camera "stuck" and not working.
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with a Nikon-authorized service representative.
Error.press shutter release button again
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with your local Nikon-authorized service representative.
3helpful
D60 won't turn on
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick. Tonya
29helpful
2answers
Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
