Necchi 3101 Mechanical Sewing Machine Logo
Posted on Jan 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Necchi supernova Julia 534
When use cam automatic sewing, the design is too close together, the thread breaks and it is difficult to make out the pattern or even if a pattern is there at all. What I am doing wrong?
  • Underworld Jan 21, 2008
    Yes, only in automatic sewing (with the cams). I use polyester thread usually. I'll make some adjustments to the tension as you recommend, thank you.
Custom Exchange
Level 3:
  • Master 397 Answers
  • Posted on Jan 21, 2008
Custom Exchange
Master
Level 3:
Answers
397
Questions
Helped
99683
Points
1012
Sounds to me like a tension issue, also are you using rayon or polyester thread, this is just a recommendation for those types of threads,,,,,,but please check your tension, is it only doing it during automatic
2answers
Supernova Julia 534. Where should I connect foot pedal?
http://www.necchimanuals.com/Necchi_Instruction_Manuals.htm
How to I drop the feed dogs on a Necchi Julia Supernova? There is a knob on the right side of the machine that should drop or lift the dogs, but it doesn't work.
There is a button with two "prongs" or wings. Rotate the prongs clockwise about a quarter turn, to face the square mark (Q in the diagram) then press it down. It will stay down. To raise the feed dogs, turn the prongs anticlockwise (to S in eh diagram) and it will pop up
https://www.manualslib.com/manual/1205574/Necchi-Automatic-Supernova-Ultra-Mark-2.html?page=7#manual
2answers
Necchi automatic supernova Julia; zig zag won't engage
There is a lever for positioning the needle bar. When you move the lever to the left middle or right , the needle bar too should follow the same. Try to do that. If it doesn't follow the lever and stays at one end, that means the machine needs to be oiled. Not like most sewing machines Supernova swings the bottom rod too to left and right when Zig Zag is engaged. I recommend to spray some WD 40 first, to inside of top and bottom side of the machine , and later to apply machine oil to every moving joints.
Necchi supernova julia power problem
sounds like a sew-tric plug an motor if so under the motor's electrical connection cover there is a wiring diagram moulded onto it
1helpful
A foot control that works with necchi Julia
call or email these sites and ask them
sewvacdoctor.com
a1sewingmachines.com
Can't get part and cam for Necchi Supernova Julia
Try the Necchi Yahoo Group. There are members who often sell parts and they also are very knowledgeable and helpful.. You should also try eBay. They have parts for lots of vintage machines. You may not find what you are looking for right away but look often as things show up everyday.
https://groups.yahoo.com/neo/groups/Necchi_Pfaff_Sewing_Machine_Collectors/conversations/messages?messageStartId=9&archiveSearch=true
3helpful
3answers
Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Necchi automatic BU supernova sewing machine
All I did was google Necchi Supernova and the second link that came up was a threading diagram...
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
