The auto focus on the Canon EF-S 18-55mm f/3.5-5.6 IS Autofocus Lens is not working, just bought last month while in Hong Kong. You can here the motor but the auto focus will not work
1st u reset the factory setting and then u see the lense is correctly fitted or not and the autofocus option is working or the manual focusing is there or not
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
You may just have the left auto focus points selected. You don't say which camera model you have. If on the back of your camera you can see a button with an icon showing 5 small white blocks in a plus sign in a white box press this to select the auto focus points. It should show the available auto focus points and then use the left/right (wheel) button to change the selection
ho.....ho... I have this prob in my canon EOS kiss SLR. CHECK THAT>>>>>>> Hold the camera vertically.Switch on the AF and let the camera to auto focus.!!!!!!!!!!!!!!!! Don't wondering....Check ur camera's sub mirror in the in side of the sub mirror.The spring that push back sub mirror from the main mirror is broken.......! How to repair this? Follow this link.... http://www.facebook.com/home.php?#/album.php?aid=2042115&id=1359757176 bye..
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
