Well it seems a hardware problem in your tape...... first of all you can try to reset your tape by removing battery and power connection for 1 hour.... if further you have the same problem then you need to open your foot pedal and then you can try to clean the chip circuit behind the non working button, use some alcohol to clean the chip.....
let us know if this works....
Good Luck!!
Thanks
I will try your suggestions and let you know if it works. Thanks.
