Jabra BT2050 Bluetooth Headset  Logo
Anonymous Posted on Dec 14, 2009
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 16, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1759
Points
29
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Testimonial: "This worked perfectly! Thanks!"
3helpful
2answers
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
I have it pair to my I phone ----but I lost my manual what are the buttons for?
Follow the instructions mentioned below to resolve the issue:
  • Charge the headset
  • Charge your Jabra VBT185Z until the solid LED turns off
  • (approximately 2 hours)
  • Turning the headset On and Off
  • Press the answer/end button until you see a burst of flashes on the
  • indicator light (LED) to turn your headset on or off.
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
For online pairing assistance visit www.verizonwireless.com/bluetooth.
Hope the above steps allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
dw
6helpful
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
7helpful
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
• Make sure the headset is off .
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
An old headset I had would flash blue and orange when it was in discover mode, ( so the cell phone would find it to pair it up). This jabra I have will not go there. My cell phone just says cannot find...
Hello friend,
First, make sure that your headset is charged and then press and hold the "Answer/end" button until that the light becomes blue solid. at this time you can do a search on your phone to discover bluetooth devices.
Here is the link to download the user manual for more information:
if the device doesn't light on at all, you may need to try with another charger because in this the device is not charged at all.
Best Regards,
1helpful
Problem pairing
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
6helpful
4answers
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
2helpful
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
