Question about Pride Mobility Products Go Go Ultra X 3 Wheel
Pride mobility scooter wont move you can hear the brake click off when the throttle is pushed but the motor does not start
  • blazero1 Jan 08, 2010
    Hi I did try to clean all the contacts and make sue all the fuses and connections were good and tight I am wondering if i may have ruined the batteries they were both brand new and i let them run down very low before i recharged them now the meter says they are full and the horn works and i can hear the click as it goes into gear but the motor wont start someone told me they may get the voltage but not have the proper amperage to start the motor I could not use the charge that came with the scooter i had to charge them with my big charger one at a time and then they did take a fill charge and read 12.7 on my voltmeter i do not want to replace the batteries unless i knew that was the only problem thanks for any help
  • janebarnett Jul 30, 2013
    hi i have same probems have u solution it
  • Pride Mobili... Master
  • 1,374 Answers
Hi, that noise could be a relay clicking off inside the motor controller because the brake on the motor has failed to release,
It quite a common problem and the only way to be 100% sure is try a replacement brake unit.
Regards
GeWiz.
Posted on Jan 01, 2010
  • 1 more comment
  • Rob Hill
    Rob Hill Jan 02, 2010
    Update, check the connections from the motor controller to the brake unit on the motor, if there is a resistance buildup (connection not clean) or bad connection , the controller will mistake this for a fault.
    Regards
    GeWiz.
  • Rob Hill
    Rob Hill Jan 06, 2010
    hi, do you really want to get the scooter working again ? if so please tell what you tried ?
    Regards
  • Rob Hill
    Rob Hill Jan 08, 2010
    hi , you say you can hear a click, that 's is the relay within the motor controller, clicking because it most likely having a problem with the magnetic brake on the side of the motor, I suggust you first trace back the cable from the brake , check the connections of this cable, normally it's a bad connection from the frame to the rear part of the scooter that causing the brake not to activate fully, that is setting up a error situration within the controller, In a similar situration I bypass the connection part and that sorted the problem.
    Good Luck.
    Regards
    GeWiz.
SOURCE:
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Stopped going when free wheel lever accidently pushed forward. Put back. Still wont start.
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
Victory scooter will just click when I push in switch and not move if I take seat off and jiggle connection at the big harness it will go
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest....
Regards
Oct 26, 2013 | Pride Mobility Products Pride Victory 10 -...
Power not going to solenide drive motor
hi, you need to check where the rear axle comes away from the main frame , the connections here are known to create problems,
Can you hear the brake unit clicking ?
remove the wheel, then remove the brake unit normally fixed by three phillip screws ,please take care not to damage the heads , now disconnect the brake unit but not the wiring, power on and move the throttle lever , does the motor turn ? then it's your brake unit that faulty or the wiring leading to it so check that out, in rare cases the controller has created a fault therefore not powering the brake so the motor cannot turn.
Motor still does not turn, then it either the output stage of the controller that's faulty or the motor itself which again is rare.
Please leave feedback if the advice helps.
Regards
GeWiz.
Feb 09, 2011 | Pride Mobility Products Pride Victory 9 PS...
Wrangle is fully charged, powers up ok, when trying to move you can hear the brake release but will not move in either direction.
bqsmc Dang scooters are a mess to troubleshoot because there are so many things that have to work to make it run. Well the brake energizing means you are getting power to the brake but the problem could be the throttle pot, or the speed control pot or the motor itself. To eliminate the motor disconnect the motor connector from the wiring harness and with two jumper wires supply 12 volts to the red and black wires in the plug. (you can jumper from one of your batteries) and the brake wires (2 smaller black wires) you might try jumping the brake first to see if the 12 volts will energize it. If not you will have to supply 24 volts the brake to energize it. If you get the brake energized then supply voltage to the motor leads and it should turn (Block the rear wheels off the ground) If it doesn't then bad motor. If it turns then reconnect the connectors. And then order a speed pot and throttle pot and replace both in the console Hope this helps
Nov 09, 2010 | Pride Wrangler 4 Wheel Heavy Duty Scooter
My dad has a pride legend and the motor gets hot and stops working. I removed the motor and took to a motor rewind place but it tests out perfect. The transaxle seems ok and now I am wondering about the...
Cody yep that could be the problem. When you engage the throttle do you hear a click from the electric brake? Its possible that the brake pad is stuck to the motor casing and causing friction thereby creating the heat you feel. Now you can't just remove the brake cause the controller looks for it to let the scooter move. You can however take the brake assemblt off the motor and tie it to the frame and see if that sloves the problem Be careful not to break the wiring to the brake. If that works and dad doesn't use any ramps (He won't have any brakes to stop him on an incline) Then he can use the scooter like that until you can replace the brake. He must be careful cause only the motor will stop his forward progress when he releases the throttle. Did Medicare buy his scooter? If so contact a provider or a service company and Medicare will pay for most of the repair. Hope this helps you
Sep 14, 2010 | Pride Mobility Products Hurricane PMV...
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Apr 22, 2010 | Pride Mobility Products Celebrity X - 3...
Pride Sonic Scooter
You can check the voltage going to the motors. The clicking you hear is the brake releasing. most likely, I bet water or something got on the controls and the signal is not getting to the controller. I hope its not the controller, they list for around $350.
Sep 26, 2008 | Sonic Health & Beauty
Pride Mobility Products Go Go Ultra X 3 Wheel Logo
2,791 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
