When I goto transfer my phone book, the blue tooth disconnects, and I can't get it to transfer into the unit. I tried it on multiple phones, a blackberry and iphone a razr and a samsung stripe, to no avail.. any ideas? Feel free to contact me at [email protected]
I got a solution:
Used hardware:
Pioneer DEH-P65BT
Jailbroken!! Iphone 3g FW: 3.1.2.
Mac or PC (addressbook on Mac or Outlook on Win)
Steps:
- Sync your contacts trough Itunes with your PC or Mac
- Go to addressbook on Mac (or Outlook on win) and export all your contacts to a vcf file (Called Vcards in addressbook)
- Copy the vcf file to your Iphone (iphoneExplorer / SSH / DiskAid or other solution)
- Download iBluetooth (I used it from the Xsellize source)
- Set up you radio to PhoneBook Transfer (Your phone is not connected to the radio at this point)
- In iBluetooth browse to the VCards.vcf and send it to the Pioneer unit.
- It now says transfer done and the phonebook is stored.
Posted this because it took me days to get it working. Haven't found a working solution on the net.
Also transfering the phonebook from another phone isn't a solution because however the phonebook will be stored it won't be usable by your iphone. The pioneer registers the phonebook to a device so it's absolutely necesarry to transfer it from the actual iphone (or send it from a laptop with a spoofed BT-Mac that matches your iphone)
- Cedrick
I have a 2009 volvo s40. My cell phone that had been downloaded to the bluetooth in car is now empty. What do I need to do to download it again.
I just transfered my phonebook, I have a Blackberry Curve 8330.
I first disconnected my device and then from my blackberry device bluetooth menu I selected transfer phonebook and that did it.
Good Luck!
Lots of older phones will not allow you to use all of the Bluetooth features offered by the Avic-d3. I upgraded to the HTC Touch from the LG-PM325 and all features work fine. Make sure after you connect the phone, you register it also. Also try using the Beam function if your phone has it.
The phone must be disconnected before you can transfer your phone book. I know it is hard to imagine, but it worked for me this morning. I disconnected my Blackberry 8310, did a phone book transfer and it worked.
In the nav mode select menu. select options. select transfer phonebook. on the phone select transfer phonebook.
cannot download contacts from iphone.
How do you set up a phonebook entry without downloading.
I downloaded it with another phone, but it won't let me access it from when connected to my iphone.
Can not transfer my phonebook from by Blackberry 8310 to the AVIC-D3....BT disconnects and then nothing happens.
I have a blackberry do you know how I upload my contacts into my Pioneer AVIC-D3?
I had the same problem with all 3 of my Razr phones. After you select "download phonebook" and it disconnects, you use your cell phone to transfer each contact one at a time by selecting it, use options(or similar) select share or send or transfer(depending on your phone), then it make ask you how,ie.e-mail,internet,bluetooth, select bluetooth, then it will either search for bluetooth device or list all the ones you have connected with, select pioneer unit.Then it will send the contact by connecting and disconnectinting, then repeat for each one...it took me a week to figure that out.
I want to transfer my contacts from the Blackberry 8320 and cant...help!!
I have a Samsung that does the same on a Toyota Landcruiser
pioneer avic 700 doesn't pair with treo 650 phone
