SOURCE: We've had our keurig B60 since last Dec...LOVED
I hope this link helps you:
http://www.keurig.com/help/brewerguides.asp?mscsid=2UFW7NLHKEAH9HHC7E9RHHP2BJBUB9ED
SOURCE: Keurig B60 only filling partial cup
You are probably using a coffee that is ground to fine. This coffee brewer requires a course grind. If the coffee is to course it will restrict water flow and shut down.
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day. I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
