The washer can spit oil if it overloaded or a seal is broken. if it is only a little bit of oil, its nothing to worry about. if it is alot then you might want to start looking at new washing machines. once the gearcase runs out of oil then the washer will not work it cost over 400 to replace the gearcase so it is better to buy a new machine
ENGINE OIL ISSUES/ OIL LEAK
The
oil is getting leaked from its running area. The oil pump has to be pressure
tested by pressure test to confirm the leak and area of leak: -----
For
step by step troubleshooting check the help links mentioned below: -----
Click
the link below: -----
http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Kia Sportage
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These
details will help.
Thanks.
FOR oil leak issue check the following help links:---
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Rear oil seal leaking?
http://schematicsdiagram.blogspot.com/2011/12/rear-oil-seal-leaking.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
---------This
will help. Thanks.
leak?
Car oil leak?
leaking oil
from timing cover?
Oil
---------This will help. Thanks.
Car oil leak?
Rear oil seal leaking?http://schematicsdiagram.blogspot.com/2011/12/rear-oil-seal-leaking.html
leaking oil from timing cover?http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Oil leaks from air filter on ford?http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Car oil leak?
FOR oil leak issue and other problems you mentioned check the following help links:---
Radiator leaking?
http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
consuming more fuel?
http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html---------
How to maximize fuel
economy on your vehicle?
http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
Check
Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Car oil leak?
