Target 's Greatland 1998 Train Set Logo
Posted on Dec 13, 2009
I need 4 curved tracks for the greatland train set. where can I find these?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
293
Points
Hi Our train engine is broke so I doubt we will find a new one.Would you be interested in buying the track.Thanks Louie @ 503 749-1011
Wiring diagram 1992 Greatland Train
Question moved from Cars and Trucks to Toys category.
A wiring diagram doesn't exist. You could take it to a model shop, or buy a second one as a template. $25
https://www.google.com/search?q=1992+Greatland+Train+Wiring+diagram
Nov 27, 2022 • Toys
1994 Greatland Holiday Express train set. Where can I get at least two curved tracks?
There are places online that sell that track. It's pretty expensive. Measure the distance between the rails to get the correct track. Greatland may have the track, but if they don't, then look online for other places.
Dec 17, 2015 • MIA Toys
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Holiday express animated train set no.387 was given to me and I have not instructions or track lay-out? HELP
The track layout is simple enough,there are 12 straight peice of tracks and 12 curved tracks. So you can make it one big circle and not use the straight tracks or add 1-6 on each sidewith straight track and you'll have a long oval. Or have 1-4 on each side then add 1-4 after the third curved track of each circlular end to have a big type oval style.
Some lites lite up right when you push the power switch on and the remaining lights will work once the train is in motion.
When the train is heading around the track, it stops on the curve, and will only start again, when you turn it off and back on??? Does this on both ends when turning the corner? Can you halp??? Tha
Check to see if the train is lifting off the track on the curve and the roller is not making contact with the center rail. Run the engine alone slowly and try both forward and backward.
23helpful
3answers
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 • Toys
Where can I purchase more track for this toy train set? CAT Iron Diesel Train Set found at ToysRUs, Meijer, Target.... The track included makes a small oval, would like to have more track so the train...
CAT Iron Diesel Train Set's price decreased by 56% from $44.99 to $19.99 at Amazon.com. CAT Iron Diesel Train set. Easy assembly just push track together. Create multiple layouts. Requires 2 AA Batteries not included
Sale Price: $19.99, Vendor: Amazon.com Full Details
Sale Price: $19.99, Vendor: Amazon.com and/or Amazon.com Merchants
Top Target Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Target Toy Expert? Answer questions, earn points and help others
