Home Logo
Posted on Dec 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some water condensations around bath fan
There are some water condensations around my bathroom fan, sometimes a few water drops. There was no rain, but it was bitterly cold around 10 degree for the past week in MN. How to fix the problem. Thanks a lot!
Anonymous
Level 2:
New Friend:
  • Expert 160 Answers
  • Posted on Dec 15, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
160
Questions
0
Helped
65043
Points
350
THATS GONNA HAPPEN WITH THE HUMIDITY IN THE BATHROOM AND THE TEMP DIFFERENCE. TRY INSULATING THE DUCT WORK FOR THE VENT. INSTALL A FLAPPER SIMILAR TO WHAT A CLOTHES DRYER HAS. U DON'T WANT COLD AIR COMING IN. INSTALL A DEHUMIDIFIER.
Wet ceiling from my bath exhaust fan, how to stop?
Probably due to 1 0f 2 things...
1- Not enough power in the exhaust fan to take out all the mist /steam from the shower.. or
2- Condensation build up due to too much steam at one time.
(especially if fan is NOT ventilated properly)
If you have access to the fan, see if the label states the CFM 's it can remove. May not be enough for the size bathroom you have.
Both of these can be solved by installing a larger capacity fan system. Make sure to vent it to the outside of the home too, since venting to a cold attic area (in winter) can cause even more condensation to drip down.
Feb 17, 2017 • Home
Drop in bathtub
people like to enjoy long, hot soak in a bathtub after a long day after work, having a proper bathtub is a must. When it comes to choosing what type of bathtub you would like, there are multiple things you need to consider.
If you have a smaller sized bathroom,
A Drop - in tub will most likely be more beneficial for space saving.
  • Drop - in bathtubs are usually lower priced .
  • You can easily have a shower head without extra plumbing hassles.
  • A drop - in tub allows you more space in your bathroom.
  • Designed with lower sides making getting in and out easier.
  • Can be fully enclosed with minimal construction.
  • Easier installation if you want a whirlpool tub.
  • Typically easier for bathing small children.
The choice of having a bathtub reflects your consciousness towards your bathroom and precise health.
And when it comes to Drop in bathtubs,
"The American Standard Evolution Bathtub"
is entirely different, universal and better fits for your bathroom.Having 21.5 inches in depth, this bathtub allows you to enjoy at least 3 inches deeper soaking bath in this bathtub. The drainage system is quick and even. American Standard Evolution Bathtub has reversible drain outlet which cleans water fast.
Read the full review to get a holistic overview including features ,specification,pros and cons.
hydro-systems-customized-bathtubs-hydrosystems-with-drop-in-bathtub-relaxation-drop-in-bathtub-nvu2yxrtj1tcjm5kl0oggpyr-5-0.jpg
May 11, 2016 • Home
1helpful
3answers
How can we get rid of the occasional sewer smell in our house?
When you next get the smell, check the traps to see if there is enough water in there to fill the trap, if one is less then it looks like water is getting sucked out when toilet is flushed or that trap (usually bath or shower) hasn't had water going in (lack of use) and water has partially evaporated.
Sep 06, 2014 • Plumbing
1helpful
3answers
Should i use the same drywall in the bathroom as in the rest of the house?
I recommend using MR (Moisture Resistant) drywall for the bathroom, and possibly for the basement if there are moisture issues. It is not much more expensive, and it can save you a big headache later
Jan 16, 2013 • Drywall
1helpful
I have two bathrooms directly under each other. The hinges on both cabinets (under the sink) are rusted and the pipes going from the wall to under the sink are also rusted. There are NO LEAKS ANYWHERE in...
You can't stop condensation or humidity in the house, especially in the bathrooms. A few choices: replace the hinges, or oil the hinges with WD-40. Install a vent fan (even though you have a window) and replace the pipes with PVC pipes. Metal drain pipes will always rust, because they drain water. Replace all under sink drain pipes with PVC
Mar 13, 2010 • Home
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
2answers
Cell phone dropped in water - red dot showing - options?
you don't need to actually drop your phone in water for there to be water damage.
simple things like having your phone in the rain, in the bathroom while you shower, around a hot tub, or possibly even if it's really humid outside can set this water damage sensor off.
it just gives phone companies more ways to void your warranty.
hope this helped.
Sep 08, 2008 • Cell Phones
3answers
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
