E000 mean when heater lamp is no on or fuse is burning,change lamp or fuse then solve your problem.E000 mean when heater lamp is no on or fuse is burning,change lamp or fuse then solve your problem.
You can't post conmments that contain an email address.
This is normally caused by a power dip.Reset it by pressing the usermode star and then # key.On the display sssw1 will display.Scroll to clear and press ok select the error and press ok.Switch the machine on and off.If this does not help the fixing unit is damage.
Thanks for the support.
E000: FIXING UNIT PROBLEM
replace or repair the fuser unit:
The fixing temperature is very low:
• The thermistor has poor contact or an open circuit.
• The fixing heater has an open circuit.
• The thermal switch has an open circuit.
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
The main thermistor reading does not reach 40°C 14 sec after the fixing heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will retain the error memory of the fixing assembly after the power switch has been turned off an then on. Execute the following in service mode, and turn off and then on the power switch to clear the memory: #7 PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
