Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Ive looked at the oven and it says LPR 814. 2,3 KW Type FCEM6 240V-50HZ.
Thanks for replying.
need brand and model number f3 is the code for a bad tempture probe its the rod in the oven cavity
