This KLH is not an 8ohm speaker, it's a single voice coil, 4 ohm speaker, rated to 150 watts.
You gain access to the speaker by removing the amp from the back of the cabinet.
The rest of SmartHome2's advice is sound, but the driver in this case is 4ohm, not 8ohm.
It's an 8 ohm driver. It need to be VERY efficient, around 90-91db @ 1w. Measure the enclosure size LxWxH then divide by 1728. That will give you your cu. ft. internal airspace of the box. Then look for a driver that will effectively work in that space. Shouldn't be too expensive, paper cone, foam surround, 8ohm impedance. Hope this helps
