Marvin 2060 Compact Heater Logo
Posted on Dec 12, 2009
Need Marvin quartz tubes
Need Marvin quartz heating tubes. I know Marvin has closed it's doors, I have two model 2060 vertical quartz heaters, need four tubes.
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jan 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
26541
Points
56
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
1helpful
The rotary switch off/750/1500 is bad. Marvin 2060 quartz heater. any replacements?
replaced the rotary switch with a double poll single T. this makes the heater a 1500 watt with no 750 watt option.
Broken quatrz tube
Contact Quartz Infrared, Inc. They are making Marvin elements, but the standard model will not fit this unit. They would be happy to help you.
http://www.quartzinfrared.com/contact.php
I need the replactment elements for a Marvin 2060 heater, where can I find them?"
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95. You can order them directly here:
1helpful
2answers
The heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
2helpful
Nonheating marvin, model 5000, quartz heater
Yes, I got my Marvin, model 500 quartz heater fixed, thank you. Please discontinue further communication.
5helpful
3answers
Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
8helpful
6answers
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
1helpful
2answers
Intermittent heater control Marvin 2060
On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
1helpful
Marvin 2020 Heater
try this place - they have replacement quartz elements maybe you can find one here.
http://www.infraredheaters.com/quartz.htm
Top Marvin Heating & Cooling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
