GE Profile Built in microwave model JVM1660BB. The turntable just quit. The turntable on/off switch is on. Cycling the switch results is minor clicking, but no change to turntable operation. Is it user fixable?
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Have a spacemaker #1650 with a motor that I can hear turning but the turntable doesn't turn. Is there a replacable gear either on the motor or the "sprocket" that connects to the glass dish? I can turn the "sprocket" manually and can feel it skipping the teeth on the mating gear inside - presumably on the motor itself.
