Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
Posted on Dec 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Food particles and spots on dishes
I can run the dishwasher and when it's done,the dishes have food paricles and water spots still on the dishes. What could be the problem? The spray arms do move so I guess its washing them. I use rinse aid also.
Anonymous
Level 3:
  • Master 576 Answers
  • Posted on Dec 12, 2009
Anonymous
Master
Level 3:
Answers
576
Questions
0
Helped
203801
Points
1663
Are the holes in the spray arms clogged? That will cause it and they're not too hard to clean out.
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Dishes have a film and food particles stick.
The film problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
I have soap build up in the dishwasher. The dishes aren't getting completly clean. Ran load today twice and they didn't look any better.
Most likely causes are:
Hope this help. Good luck.
1helpful
Unclean dishes food particles left on glasses
Sep 11, 2009 • Dishwashers
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
2helpful
2answers
I have a adb2200awb amana dishwasher which leaving glasses with a cloudy plus grid stuff on the glass and on the dishes. i use jet dry stuff plus the talbets with jet dry in them also i put them on a 2hr...
This is a classic sign of too much detergent. Are you only using one tablet? Too low of a washing temperature could also be your culprit. Dishwasher detergent needs to be washed with at least 120 degree water. Check to make sure your supply is hot (if it's plumbed to intersect with your faucet, just check faucet hot water supply temp). I'm not sure why you're running it on a two hour cycle, dishwashers can generally do the job in about 40 minutes. The grit is probably because there are food particles in your food trap. Make sure the food filter beneath the spray arm (if equipped) is clean and check the lowest areas for food scraps.
2helpful
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
2answers
Microscreens on Maytag Dishwasher
where to find the sand filter on a maytag dishwasher?
Nov 01, 2007 • Dishwashers
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
