Question about Fossil Watches
Changing the date on a fossil watch- how do you do it?
  • millermand
    millermand Mar 23, 2013
    I have a Fossil watch, CH2586. One thing about this watch, that really irritates me, is that it automatically thinks that every month has 31 days. This means, that by the end of each month, you have to manually regulate it to show the correct date.
  • millermand
  • 530 Answers
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Posted on Dec 12, 2009
SOURCE:
escapement
  • 2338 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
SOURCE: Adidas watch
Troubles you to help the solution to look for adidas the adx156 instruction for use, thanks!
Posted on Feb 27, 2008
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
SOURCE: Fossil JR9589
(I'm dutch, so I'll try in my best englisch)
I don't know if you still have the problem, but what you should do is te following:
* pull out the knob (2 times) and turn anti-clockwise to change the time
* keep doing until it's 24.00 (midnight) and you day change's to the UK (!) day.
* push back the knob (1 time) and change the day to the FRANCE (!) day by turning anti-clockwise
* pull out the knob again and turn anti-clockwise to change the time until 03:00 (midnight)
* you see the then change the day back to the UK day
So, every night at 00:00 the day changes to the FRANCE notation and at 03:00 it then changes to the UK notation, so you can enjoy this setting during the day.
Good Luck.
Also owner of JR9589 watch.
Posted on Jan 02, 2009
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
Need help with date change in a fossil me1135
Google (fossil)(me1135)(manual) without parens for date change instructions.
Mar 14, 2015 | Fossil Watches
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
Feb 02, 2012 | Fossil Stella Topring Watch
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
Jul 13, 2011 | Fossil Watches
Fossil bq 9011349908 cannot set date and day
mcdevito75 here, There are many versions of Foosil watch, If yours has a stem (winder) it"s 2 position, to set Day pull stem out and rotate the hands till the day appears, push stem in all the way, Now slip your fingernail just under the crown and lift stem to it"s first position this will allow the date to change. You can also visit Fossil Watch online at Fossil Watches.com or visit a small watch repair shop in your area for adjustment help.
Jun 27, 2010 | Bulova Watch
NEED TO RESET THE TIME, NOT SURE HOW TO DO THIS
Go to www.fossil.com and go to customer care. Once there go to watch manuals and look for your watch.
Apr 06, 2009 | Fossil AU4003 Wristwatch
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Watches Logo
1,358 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Janelle Schoonover
Janelle Schoonover
Are you a Fossil Watch Expert? Answer questions, earn points and help others
