I have the hdmi cable and the audio cables. "no signal" message on screen.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
