GE 27933GE2 Cordless Phone Logo
Posted on Jan 20, 2008
Replacement Battery for GE 27933GE2
Unable to locate replacement battery. Can not find User Manual. Can anyone provide a usable manufacturer identification and model number for battery for this cordless telephone?
  • Anonymous May 04, 2009
    I need a replacement Battery for GE 27933GE2"
A
Anonymous
3SN-AA60-S-J1
check out the lenmar.com site. they sell a replacement NiCad battery for that phone. i'm in the process of replacing mine.
3.6V, 600mAh
Trying to find model number on my GE universal remote so that I can get codes for my converter box
Locating the model number on a GE universal remote can vary depending on the specific model. Here are some general tips to help you find the model number:
  1. Check the Battery Compartment:
    • Open the battery compartment on the back of the remote.
    • Look for a sticker or label inside the compartment that may contain the model number.
  2. On the Remote's Front or Back:
    • Check the front and back of the remote for any labels or markings that might indicate the model number.
  3. User Manual or Packaging:
    • If you have the user manual or the original packaging, check there. The model number is often mentioned on these documents.
  4. Behind the Battery Cover:
    • Remove the battery cover and inspect the area behind it for any labels or markings that include the model number.
  5. On the Remote's Body:
    • Inspect the body of the remote itself. Some models may have the model number printed on the front or sides.
Once you locate the model number, you can then proceed to find the correct codes for your converter box. The codes are usually included in the remote's manual or can be found on the manufacturer's website. If you are unable to find the model number or the manual, you may need to contact GE customer support for assistance.
If you provide more details about your GE universal remote, I might be able to offer more specific guidance.
Built in Touchstone electric fireplace is flashing F2 and beeping
The F2 error code on a Touchstone electric fireplace typically indicates an issue with the temperature sensor or the thermostat.
Nov 25, 2023 • Ovens
1helpful
Channel Master DVR clock loses time . is there a battery replacement procedure needed ?
It's possible that the DVR's internal battery is losing charge, causing the clock to lose time. Typically, DVRs use a small lithium battery to power the clock and other internal functions. Over time, this battery can lose its charge or fail entirely, which can cause the clock to lose time or reset completely.
To replace the battery in your Channel Master DVR, you'll need to open up the device and locate the battery. Depending on the model of your DVR, the battery may be easily accessible or it may be hidden inside the device. You may want to refer to the user manual or contact Channel Master for specific instructions on how to replace the battery in your model.
Once you've located the battery, you can replace it with a new one of the same type. Lithium coin batteries are a common type used in electronics, so you should be able to find a suitable replacement at most electronics stores. After replacing the battery, you may need to reset the clock and other settings on your DVR.
I have a GE rapid clean II J55BF-1 wall mount oven needs to replace the baking element. Did someone happen to know the part number of the replacement baking element ?
To find the correct replacement baking element for your GE Rapid Clean II J55BF-1 wall mount oven, you can try the following steps:
  1. Locate the model and serial number of your oven. This information is usually found on a label on the inside of the oven door or on the back of the oven.
  2. Visit the GE Appliances website or use an online appliance parts retailer to search for the part using your oven model number.
  3. Look for the baking element part number in the oven's user manual or service manual. These manuals may be available online or from the manufacturer.
  4. If you are still having trouble finding the correct part number, consider contacting the manufacturer's customer service department for assistance.
Once you have the correct part number, you can order the replacement baking element and follow the manufacturer's instructions for installation.
Nov 28, 2022 • GE Ovens
How do I access the battery in the cordless handset
GE 30524EE2 DECT 6.0 Corded/Cordless
Don, Battery replacement is on page 13 on the first link. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE 30524EE4 User Manual Battery Installation
http://www.videofon.rs/ge/pdf/30524.pdf
http://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf
1helpful
How do I open this phone to change batteries
The battery replacement instructions are in the second column of the first page of the manual: Owners Manual User Guide for GE 29267GE3 Corded Phone
My GE cordless phone Model No. 28112ee3-a is not functioning and it keep beeping. I once found a code to stop it from beeping. can anyone help?
The GE 28112EE3-a was made by Thomson with the GE name. The manuals for most of these phones are available here: http://www.home-electronics.net/user_guides.asp . The direct link to the manual is http://www.home-electronics.net/USER-GUIDES/28112_DOM_EN_CL_IB.pdf .
What type of beeping are you hearing? If you are hearing a beep every seven seconds from a handset, the solution is to recharge the battery. If the battery won't hold a charge, then replace the battery with a 5-2721 Nickel-metal Hydride battery.
The handsets can also beep for about 2 minutes if another handset or the base pages them. This is a locator tone. Just press the Talk/Call Back button or the Tone/Exit button on each handset.
I hope this helps.
How to install memory
Unplug the laptop from the power supply. Remove the battery. Locate your user manual (hard copy or printed from the internet for your laptop's make and model). Now, open the bottom of the laptop, locate the memory bank and follow instructions for memory installation provided by your laptop manufacturer in the user manual.
How do i replace a cmos battery in my hp compaq nc2400
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in
RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOS http://www.youtube.com/watch?v=P_cxAireIsw
My camera, even with fully charged battery, the lens does not close all the way when you turn power off. And , often must shut on and off to take pictures. Also, sometimes shuts down when taking...
edkhim:
It sounds like your battery has reached the end of its usable life. You have done very well to get several years worth of use out of the original battery, but it's time to buy a replacement battery and recycle the old one.
From page 9 of the user manual for this camera (click here for user manual), this camera uses a model DMW-BCE10PP lithium ion rechargeable battery.
Luckily, this model of battery is currently on-sale at Amazon.com for $19.77 as of 2:45AM Feb 17, 2011! (click here for link)
Disclaimer: Please note that I have done my best to try to provide the correct information about the type of battery that you need and with the troubleshooting of your issue; however, there is still a chance that that I have not correctly diagnosed the issue and that the battery I suggested above may fix the issue or even may not work with your camera. Please double-check my diagnosis before purchasing anything!
Thank you for using FixYa
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
