Question about Uniden Cordless Phone
Uniden 5.8Ghz phone.
When i connect the phone line to the uniden phone, both the uniden main set and the uniden cordless phone start ringing without any actual incoming call. the cordless handset shows the message INCOMING CALL.the ringing stops only when i press the STOP button on the main set and the END button on the handset.but the message,INCOMING CALL keeps on flashing on the screes of the cordless handset. but after that, both of them dont ring even there is an incoming call
  • 2 more comments
  • Anonymous Mar 15, 2014
    I can hear the person and they hear me but with outgoing calls the person can't hear me but I hear them
  • Anonymous Mar 18, 2014
    will not ring with incoming call
  • Anonymous Mar 23, 2014
    line on hold won't connect
  • Anonymous Mar 26, 2014
    model dect1588-5
  • 39 Answers
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 22 Answers
Don't be a scab. The Base is %)&%. Lash out. Spend $70.00 AU & update. Remember: A microwave operates at 2.4Mhz. A handset at your ear at twice that? Very little Watts, but still?
Prefer lower frequency for ground base penetration. WHY do you want or need such penetration?
Posted on Jul 03, 2009
SOURCE:
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Jul 24, 2011 | Uniden Cordless Phone
Tip
Connecting extra handsets to main base
Call your phone, while it is ringing put your extra handsets on the main base. I did this and they started to ring when on the base and they worked after that. You may not need to call the main line, only put the extra handsets on the main base to get them connected but I didn't try this so I don't know.
on Oct 18, 2008 | Uniden Cordless Phone
How do I turn off my ringer on my Uniden 5,8ghz expandable cordless phone system
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to download a copy of the manual.
Jan 08, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
We need a manual for cordless phones - lost ours
Here is a link to the GE website with manuals. I found 5922 EE1 and EE2. I wasn't able to find FE2, but I bet that one of the 5922 manuals will probably help...
http://www.home-electronics.net/ge/pc/user-manuals.asp
Dec 28, 2008 | Uniden Cordless Phone
Changing the amount of rings on uniden DXA15188-2
On the main base, press the menu/clock button 3 times, it will give you 3 options...2 times, 4 times, and 6 times, press set.
Jul 29, 2008 | Uniden Cordless Phone
Idect x1 cordless phone
i have the same issue but cant find any info on it
Jan 16, 2008 | Uniden Cordless Phone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
1,627 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
