I have a NEC Valuestar vs7004da japanese machine. I was able to load xp sp2 with minimal problems but when I go to load the japanese zenrin NEC drivers disk it gets to 1% and says it is missing a .zsc file on the c drive. Also all the install windows have odd characters where there should be writing. I loaded japanese language support and it still does this. Help
Sir try copying all the files in the installation disk to your hard drive then run the installation in where you copy your file... probably just a read disk error... if you have successfully copied all the files means disk is still working... if you get an error chances are the installation disk is damaged or your disk drive have a problem.
You can download drivers from the NEC WEB site. Please click
on this
link and select your model computer/notebook and the Windows XP or
Vista drivers you require :-.
Had already tried that the files all copied to the hard drive with no problems but still errored out on the install.
nec
I have bought a second hand pc vs7004da. when formatted and reloaded windows xp tv card driver, vga driver and sound drivers are not loaded. I cannot find all these drivers. what can I do
