Question about Motorola Mobility RAZR V3
Phone only on bootloader
When I turn on the razor, it only comes on in the bootloader mode, thats it! Is there anything at home that I can do to make the phone operate normally and get it out of bootloader mode?
  • latinopride0 Dec 12, 2008
    when i first turn my phone the boot loader screen comes up.
    Scholar:
  • 117 Answers
Bootloader is the programing mode for when motorola loads the operating system. Typically this will happen when a bad flash code is used. You can try and remove the battery while the phone is turned on and hope it reloads the OS. Otherwise talk to your carrier about warranty stuff.
Posted on Jan 20, 2008
SOURCE:
Use the phone
your phone is starting in flash mode..try and hold the palm key and the star key at te same time while turning on your phone.. that is the way u start a razor in flash mode,,mabey it will take it out of that mode
Feb 17, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
Bootloader usb init
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Jul 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
BOOTLOADER USB INIT - BUT PHONE WON'T COME ON.
you need to take the phone to a mobile service center and have them reflash the phone to have it working properly
May 29, 2009 | Motorola Mobility RAZR V3
My razor v3 is stuck on the hello screen and do not turn off by pushing the power off button.
Sounds like the firmware has gotten stuck it was a common bug in some of the v3 firmware versions. Pull the battery, replace it and then power on while holding down the # and * keys it will go into bootloader mode. Once on the text bootloader screen you can use flashback (google for it) and flash a more current firmware which will fix the phone.
Jan 07, 2009 | Motorola Mobility RAZR V3
Bootloader USB INI
It sounds like to tried to hack the phone,,never heard of bootloader
showing up unless you tried to load it, you probably can't fix this unless you know how to look at the firmware that runs your phone.
Best thing is too take it too your carrier store that has a repair
on hand or sent it to moto, if you tried to hack they will charge you
for messing with it, if you did not then it should be free,,should be,,
Also wait and see if you get a better answer,,,I have only hacked
all razors Iphone, lg vu, never touched the phone you have.
Dec 30, 2008 | Motorola Mobility ic502 Cellular Phone
My motorolav3m razor phone is on the fritz
you need to take the phone to a mobile service center and hvae them correctly install the firmware back on the phone
Dec 07, 2008 | Motorola Mobility RAZR V3
Hellp razor problems!!
take the phone to a mobile service center and see if they can help you better with this problem.
Jun 12, 2008 | Motorola Mobility RAZR V3
Bootloader
  • ok to program
  • transfer mode:
  • serial rs-232
  • the same problem...help...!
Dec 22, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3 Logo
367 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
