A program, or an Application are both programs, but the former will be accessed through the program manager [PRGM] and the latter through application manager .[APPS] .If it is a program (in the context of the TI84Plus) you press [PRGM]. You see three menus [Exec [Edit] [New]. If there are any programs in the calculator, you should see them under [Exec] and under [Edit].
A. To RUN a program
B. To edit a program
Hope it helps.
Thank you for rating this solution.
I showed you where you would find your program in the calculator, if you successfully transferred it. I also showed you how to open it for editing to correct programming errors. If you get a message with GOTO, just press the ENTER button and the calculator will show you where the error is located.
The message "undefined" appears each time you try to use a variable, a function, a program that you called for execution but did not define prior to calling it, or does not exist anywhere on the machine.
It might help solve your problem, if you took a fraction of the time it took me to write the answer, to tell us what program you want to run, what message you get (the whole message).
If no comments are forthcoming, I for one will conclude that you are no longer interested in solving your problem.
