Here is a simple way to fix the problem. (this will also work on xp)
at login screen. click on the password entry field & press ctrl+alt+del
it will give a new login window
put Administrator as username and leave password blank, and hit enter
or
at pc startup, keep pressing f8. you will then get a menu.
select safe mode and click enter.
now you should see a login screen.
there will be an administrator account. by default this has no password.
log in to this account and go to user accounts and remove the old password.
if this doesn't work you can try using the super admin account.
here is a guide.
http://www.computerperformance.co.uk...r_activate.htm
if all these fail.
download this
offline nt password & registry editor
http://www.pogostick.net/~pnh/ntpasswd/
there is a guide on the site on how to use it.
also this programme is on hirens boot cd
http://www.hiren.info/pages/bootcd
which is an invaluable group of programmes for your pc.
also to burn a bootable cd i would recommend a programme called imgburn
http://www.imgburn.com/
here is a guide on how to use it
YouTube- How-To: Create a Bootable CD With ImgBurn
You want to reset admin password for your Windows ? It is a good suggestion that you download Windows Password Unlocker from its official site, which allows to reset the forgotten Windwos admin password quickly and safely with less than 5 minutes.
You can use such windows password recovery tool to help bypass windows password,including your forgotten windows administrator password and user passwords.Try this.
You can recover windows password with windows password recovery tool. I know a tool named "windows login recovery" that can remove windows password without losing any data and you needn't reinstall windows OS. Download it from http://www.windowsloginrecovery.com and burn the program to a blank CD or a usb flash drive, insert the CD into the problem computer and reset your password to “Blank”. By the way, it is also useful to recover administrator password.
Sorry to let you know when you redo a administrator password lock and open it and the hard drive is got a lock on it,you can't redo hard drives passwords. You have to change the hard drive.
Windows admin password forgotten is a normal thing nowadays and many ways you can choose to unlock. If you have a reset disk you can use it crack directly; if don't have, you can create one by yourself with blank DVD/CD or formatted USB flash drive. To create one you can download Ophcrack or Anmosoft Windows Password Reset. But personally, I strongly recommend Anmosoft, which is more effective and safer and you can learn more from:http://www.resetwindowspassword.com
