These trackers are notorious for the wiring to the sending unit on the top of the fuel tank rotting. My bet is this is your problem and not a fuse. If you do drop your tank and your luck is anything like mine :( you will see there is allot more in need of replacing. I replaced my tank and sending unit due to all the rust. Somewhat costly but in the long run it was worth it. you may be able to just replace the sending unit by removing the screws on the top of the tank and dropping in a new one but mine was so far gone I could not get the screws out. If your wires to your sending unit are rotted I would bet your wires to the fuel pump are not in very god shape either.
Fuel tank have to come down
SOURCE: the gas guage on my 2003 toyota sequoia stopped working
I would check the fuse first, and if that isnt bad, there is a float in the gas tank that sends a message to the gauge to how much gas is in the tank
SOURCE: instrument guages stopped working
Hi, this could be as simple as a blown fuse. It could also be because of failed general parts. i would first check the fuse box to make sure all the fuses are good then, i would check the wire connections on the back of each gauge to see if they may have become lose or separated form the housing.
SOURCE: Gas guage, Temperture gauge and RPM guage stopped
Send cluster out to be checked and or repaired to Model Electronics.
SOURCE: Dash guages quit working. Gas, temp, tach and
Try disconnecting battery for couple minutes and see if it starts working again I have done that in the past
SOURCE: 1994 Toyota Tercel blinkers and air stopped working
Check the fuse/connectors at the battery post.
