Is the noise a thumping noice? How old is the washing machine? Did it just all of a sudden start making the noise? Have you tried running machine for a cycle empty? If so is the noise still there?
several explanations for noise,
I assume when you say agitating it is a top loading machine.
so 'hard time agitating' meaning the agitator is slow? Or skips?
try running machine with nothing in it and report back.
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
HI There Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem. It's noisyMost
it. Repeat these steps if necessary. Let me know how this goes and thank you for writing to fix ya. Best Regards Richard
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
