Hi I just reconnected my KLH surround sound system and found the subwoofer makes a loud hum. Ive tried moving it away from other electronic sources, put a choke on the power line and also plugged the power cord through a 3 prong. I've tried in a seperate room but whenever I turn it on, no matter what volumn level, I get the hum. The unit is a KLH Bassbite V. Any suggestions. Thanks, Jeff
the 4700uf 25V filter caps are blown. you can see them with their bulged vents when you remove the back plate as everything is attached to that plate. They are the biggest black can ones on the PCB and they are super easy to replace. solder pad is right on top, desolder, and replace both at about .60 a piece. remember to place stripe side on new capacitor on the painted side of the pcb as they are polarized.
