Question about Motorola Mobility S9 Headphones
What does 2 flashing blue light mean on the S9.
  • 311 Answers
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Posted on Dec 27, 2009
    New Friend:
Mine will not pare, light will not stay on.
What to do?
popsk41@comcast.net
Posted on Aug 20, 2012
6ya staff
SOURCE:
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
How do I put the motorola s9 hd wireless headset in pairing mode for a iPhone 3G ?
Starting with your headset turned off, press and hold the power button for some 6 seconds, until the indicator light flashes alternately in blue and red. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a while the S9 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros). The indicator light will flash some times and enter stand-by mode.
Hope it works for you.
Regards, Carlos
Sep 01, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
Feb 22, 2009 | Motorola Mobility S9 Headphones
S9 nvr goes into paring mode
Hello,..... when pair the S9 you must press and hold down the power on button till the led flashes blue and red...at this point it will be in pairing mode....
Feb 09, 2009 | Motorola Mobility S9 Headphones
Motorola Mobility S9 Headphones Logo
2,045 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
john h
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
