I think the problem lies with your dual core processor. Under Windows XP, these processors need to have the correct drivers installed to fully take advantage of the fact that they have 2 cores.
Try downloading and installing these drivers from the AMD website:
Dual core optimizer Processor driver
As always, back-up your important data, and preferrably create a restore point before going through with driver updates.
The radical choice is, obviously, to reformat using your own disk, as this should install correct drivers for all your hardware.
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
