have you checked voltage and ground for blower motor? At the blower motor, red wire is voltage, black wire is ground. You can take two wire connector loose from blower motor, use both ends of testlight on connector wire terminals, Key on--hvac controls on--hi speed. If the lamp comes on, you have voltage and ground good enough for test lamp. If you have good voltage and ground for blower motor and the motor doesn't run, suspect the blower motor. If the lamp doesn't come on, your missing either voltage or ground? In stead of using wire connector ground, you could use chassis ground, clean metal spot, probe red wire, If lite doesn't come on, your missing voltage and you'll have to backtrack circuit. See the top right fuse, 40 amp fuse, that fuse is only for hi speed. Not only check the fuse, use a test light check fuse for voltage, hot all the time. If you follow that wire down, in diagram, you see it goes to switch side of relay, left side in diagram. When that relay is energized that short line moves to other terminal carries voltage for hi speed. The control side of relay, right side in diagram, needs voltage and ground in order to energize. If it doesn't energize, no voltage hi speed. Orange wire is voltage for control side, black wire is ground. I can only help with testing, good luck.
