Kitchen Ranges Logo
Posted on Jan 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool electric stove
I have a whirlpool electric ceramic top stove. The large element seems to cut in and out it takes forever to boil a pot of water. We have bought new cookware made specifically for ceramic top stoves but the large burner gives us problems. I can boil water on the smaller burners faster than using the large. The only other problem is that the hot surface indicator stays on all the time for this burner can this be related to the problem. What can I replace ? Is there a sensor or maybe the thermostat? The model is RF386PXGQ1 super capacity 465
  • 1 more comment
  • afp1999 Jan 20, 2008
    Is is correct that the hot surface indicator sensor is built into the element? What switch are you talking about? Can you ggive me part #'s?
  • afp1999 Jan 29, 2008
    tech17
    great job.....stove works better than new
  • Anonymous Mar 30, 2014
    repair faulty themostat
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Jan 19, 2008
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
897526
Points
3823
The sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
  • Anonymous Jan 20, 2008
    yes it is it comes with the element and is the long rod you see when the element is on iff you look through glass the other is the infinight switch you turn it on with where the knob is just replace them both and will save you from having to raise the top but once
  • Anonymous Jan 29, 2008
    well how gracious thank you very much
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1720
Points
0
My sister has a whirlpool electric ceramic top stove/accubake sistem....the problem is that my husband took the door of the oven off to clean and now he can't get it back on......where on vacation at her house and want to fix it before we leave sept. 30/08. We need help fast.
thank you
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 • Ovens
The electric burner elements on my whirlpool Super Capacity 365 stove often won't heat. They seem corroded on one tip and the socket they go into looks dark. Can I simply replace them?
YES YOU CAN . FIRST TURN OFF THE POWER TO RANGE , THEN LOCATE THE SCREWS ALONG THE SIDES OF THE TOP REMOVE AND YOU SHOULD BE ABLE TO SEE THE ELEMENTS AT THE END OF EACH ONE THERE IS A TWO PRONGED CONNECTION REMOVE ELEMENTS FROM THESE PULL OUT TAKE ALL THE ELEMENTS TO AN ELECTRICAL AND PLUMMERS SUPPYLY STORE FOR REPLACEMENTS, REFIT NEW ELEMENTS AND YOUR COOKER SHOULD WORK FINE , GOOD COOKING .
1helpful
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Our Whirlpool speedheat 2600 burners shut down whenever we try to boil water when canning or even making pasta, what do we do?
If the pot is too large or to small for the burner or is concave or convex, the burner will short cycle. Try to match the burner to the pot and be sure the pot is nice and flat on the bottom.
1helpful
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
1helpful
Whirlpool R365 Large Burners won't work
The problem could likely be in the sockets that the elements plug in to. Over time, they lose tension and deteriorate. The replacement sockets are relatively cheap and easy to replace. If the connection ends of the elements are still in good shape, there is really no reason to replace the element.
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
