Question about Mitsubishi WS-55511 55" Rear Projection Television
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
  • Anonymous Dec 10, 2009
    its was a 2 and then 2. how do i fix it
    its a Mitsubishi WS-55511
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
if this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 10, 2009
Testimonial: "thanks but i know whats wrong but how do i fix it? "
  • 5 more comments
  • SD Tech
    SD Tech Dec 10, 2009
    oK, LET ME explain. What it means is one of the two soldered in fuses for the convergence circuit is blown---I have photos that show them so you can find them and also a photo of some resistors in front of them that need to be looked at--fairly easy stuff.
    I have about 3 pages of Step by step start to finish instructions. They tell you everything you will need and how to do the repair. It involves two things--getting at the chips and being able to solder etc.
    Confirm to me actual model number and I will post the instructions here for you--you can read them and decide if you can do the repair. EBAY is the best place to get the chips (some models use one and others two chips---the reason I want to know the model number.
    SD TECH
  • 210014640 Dec 17, 2010
    SD Tech - just checked my Mits WS-65819 and when I run the test of holding MENU INPUT down I get 2 blink and then 2 blinks. Can u pls email me the 3 pages of instructions for fixing the convergence circuit. According to your msg 1 of the 2 soldiered circuits is blown.
    Appreciate your help
    Dan
  • SD Tech
    SD Tech Dec 18, 2010
    @ Dan, post a question in the free section attention to me and I will help you for free.
    SD TECH
  • jiggy_d Apr 23, 2011
    Hello, I have this 2 blink pause 2 link issue. How do I fix this? Thanks
  • Gazurk Jun 06, 2011
    I have 2 blinks then 3 blinks. Any fix?
  • Ashley Sims Dec 06, 2011
    This is exactly what is wrong with mine. I have Mitsubishi WS-65315 could you point me in the right direction?
  • Shawn Pullen
    Shawn Pullen May 05, 2019
    Just had this issue 2 blinks and 2 blinks, where can i get the 3 page fix?
    New Friend:
Hi. I love my tv but I don't understand what's going on..? When I did the menu/input test a months ago, it did 2 flashes, paused, then 3 for code 23. I unplugged it and tried it again today and it does 1 flash, pause, then 2; which says "no error," but I have no screen :(
Posted on Apr 02, 2011
4 Suggested Answers
6ya staff
SOURCE:
SD Tech
SD Tech
  • 14553 Answers
SOURCE: my 65 inch projection TV turns off within a few
If power light does come on and a few seconds later it goes off---do the self check that the WS65909 MITSUBISHI should have:
On the front of the set press and hold both the MENU and INPUT(OR DEVICE) BOTH FOR 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light should blink a two digit code--error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what code you get----it will repeat it several times---and I will tell you what it means.
SD TECH
Posted on Nov 03, 2009
Anonymous
SOURCE: Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
Even, I have the same problem...looking for a help on internet but not finding any...if you know...please post on this site.
Thanks,
Posted on Jan 13, 2008
Anonymous
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
I got no image & the tv turn it offa few secondes
Do it work after some time? Is picture and sound are OK after that? Provide more details please.
May 29, 2012 | Philips Magnavox 20MT133S 20" TV
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at blake.shewmaker@fnbky.com.
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
6,036 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
