HP LaserJet 4000n Printer Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I just took a router out of my system and now my HP 4000 N LaserJet is directly wired to my Mac G-5 via Ethernet, but when I try to print I get the message "printer not responding". Yes I've checked the cables and made sure the printer was on and checked everything I could think off. In my Network preferences "Built-in Ehternet is currently active" and gives an IP address. It also shows a number for the router that I have removed. Could that be the problem? Bob R.
PrintDocta
Level 2:
Novelist:
  • Expert 217 Answers
  • Posted on Apr 05, 2010
PrintDocta
Expert
Level 2:
Novelist:
Answers
217
Questions
0
Helped
142679
Points
337
You will need to use a CROSSOVER patch cable.
If all IP addresses are manually set (i.e none obtained from a DHCP server), and the addresses are unchanged from when the router was in place, everything should work. But if you're using a normal patch cable, it won't - you need a crossoer cable.
Hp laserjet wireless not found on my phone
why not RTM? (omg)
read the manual,
all this is covered there. how to CONNECT.
there is no phone support, apple or android. only xp to w10.
on newer printer, far newer, the phone can be linked to HP smart print servers and to your home system printers.
https://support.hp.com/us-en/product/hp-laserjet-pro-cp1025-color-printer-series/4052955/model/4052971/manuals
here is HP site page showing how to do that,
http://www8.hp.com/us/en/ads/mobility/overview.html
first pick a printer that does that.
using the smart app
or ePrint.
there are many ways to set that up, but direct cell to printer.
no. (yes new products can do direct cell print)
that is called wireless direct print , features, as see here.
http://www8.hp.com/us/en/ads/mobility/wireless-direct-printing.html
you said you have phone (cell apple or android?_)
then said have a laptop.
my cell , is android and I use local wifi , to save 3g charges
do you?
my laptop has internet connections 2 ways, wired, and wireless
does yours have wireless. seems not.? but.... do you?
you said no router, but if you go to any ISP today
and he installs internet service, there are 2 hidden router now
inside the old name modem,
the modern cheaper modem has that, hidden is side.
has 3 things in the black box.
so what do you have there that we cant see, devices to the ISP
with names and model numbers.
knowing that tells the helper what is possible , (all things)
my guess is you want to print, using the CELL.
if you dont have eprint mail the docs or photos to the laptop
then, print from Laptop
to printer using a USB cable, (USB is 10x more easy to make work)
your printer can connect up 3 ways.
Printer USB to PC. direct wired printing. ( always a choice, direct)
Ethernet to router. wired. (all things connected to this router can print.
wireless to router. printer to router joined, and print from any thing at home connected to said router.
if it must be wireless, (you must have that?)
then buy a router. and use that, and is safer behind any router firewall vastly saver too boot.
tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
Can a dynex DX-ESW5 act as a print server?
No. You need a router to set / obtain an IP or connect it directly to the computer RS232 serial port. No network required, but is old school and may be difficult. Specially with MAC. You are better off getting a new router.
1helpful
Today I bought and installed a Linksys Wireless-N router. Everything is working well (two laptops wirelessly and two TiVo adapters wired), except for my hardwired (via Ethernet cable) HP LaserJet 2420dn...
set the printer up manually with a static IP address. To do so, go to the setup menu under network settings and select manual.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
1helpful
Will not print Photoshop file
Have you check to see if this is a postscript driver you are using?
k24674
Grand Canyon Tech
Grand Canyon Tech
