Sansui HDLCD1908 19 in. LCD TV Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Activating HD mode
How do i activate hd on a new Sansui HDTV (HDLCD1909)?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Dec 10, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368278
Points
33650
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
2answers
2answers
Turn off night mode
Press the SPK (Speaker) key then enter the appropriate service code...
Service Code
818 + 1 Activating Day 1 Mode
818 + 2 Activating Night 1 Mode
818 + 3 Activating Midnight 1 Mode
818 + 4 Activating Rest 1 Mode
818 + 5 Activating Day 2 Mode
818 + 6 Activating Night 2 Mode
818 + 7 Activating Midnight 2 Mode
818 + 8 Activating Rest 2 Mode
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
2helpful
Polaroid HD TV 32" Black square in the center of the screen,
Is your closed caption selected? I saw the same problem with my friend's Sansui HDTV.
How to activate HDTV on RCA D61W20B
U can't only receive HD the mode is 1080i is the HD signal.Some HD signals are free the rest must order HD package from cables or satalites signals to have more.
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
1helpful
2answers
Sansui tv dtv2784
No this TV is not HD ready. However it is digital (ATSC) ready meaning now that most of the analog brodcasts have stopped it will receive the digital broadcasts so you don't need a converter box. Since it can only display 480i resolution it is not HD ready. You would need a TV that can display 720p or better to be considered HD ready.
Hdtv
Call the customer service number on the back of the tv. They can tell you. Have your model number
ready.
HDTV Ready
your ready, just connect the cable directly and the ntsc and atsc will auto search all channels and the dijital channels along with HD channels. but the paying channels like HBO and cinamax you will need a HD Box. to allow you to see them.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
