Archos 504 500870 Digital Media Player Logo
Posted on Dec 09, 2009
Where is my serial number for my archos 504 , i
Where is my serial number for my archos 504 , i need this for adding a plugin
deiphagus
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Feb 07, 2010
deiphagus
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
4601
Points
36
Remove the battery and read in the sticker of the exposed 2.5´´hard drive.The serial number is indicated with SN or S/N plus several numbers.
How can i put dvds on my 504
You can drag and drop dvd files (divx/avi+AAC codecs) into the video folder of the device, but in order to play the you must buy the Archos cinema plugin. Visit the Archos official page and search your model.
ARCHOS 504 160 GB
As long as you replace the hard drive with the same exact one, it should be possible. You can contact the manufacturer with the below options and they can assist you in getting a new drive.
Main support number (877) 300-8879
Email support [email protected]
Let me know if you need any more help and good luck to you
2helpful
Free archos plugin
plugins are connected to the device serial number
so you need to pay
5helpful
2answers
Archos screen only
solution found!!!!!!!!!!!!!!!!!!!!!!!!!!! thank you so much for the support of the Archos team. here is what i did to repair my 504
if your "reset" button doesn't help at all, this is what you'll do.
If you power on the unit by pressing and holding the TV/LCD button and power
button simultaneously the unit will boot into a recovery screen. Once in this
screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of
the unit:
http://update.archos.com/4/a504/a504_r1.6.53/a504.aos
before i found this solution, i've already given up on my 504, but now it's back!!!! REBIRTH!!!
thanks once again to Tony H from Archos Technical Support
2answers
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
3answers
Placing films onto the 504
I have put plenty of DVDs onto my Archos, but I use the optional cradle which connect to the TV as well as DVD players. You simply connect the DVD player onto it and play your dvd, which switching on the Recorder function on your unit.
Alternatively, can you convert the DVD onto your PC and then transfer onto the Archos in normal fashion, or is this what you are saying you tried to do already?
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
