Question about American Standard Home
My bathtub drains incredibly slow. After a 5 min shower there is about three inches of water in the tub. It usually takes up to 10 min to completely drain. I have used Liquid Plumber, both the one for clogged or slow drains, and also the Pro strength . The tub and bathroom sink both drain into the same main line. The sink doesn't back up. Any thoughts on what i could do next?
  • campbell_jac Dec 10, 2009
    That can't be it. I bought and used one of those Turbo Snakes (the 'as seen on TV' deals)and only got like three or four strands of hair. I also cut the pipe about 8 inches away from the tub, all the way to where it joins with the sink drain, and replaced it with new PVC pipe. I figure the problem might be with the main waste water drain, but I have no clue as to how I go about resolving that. A coworker suggested dropping a hydrochloric acid down the drain, but can I do that without really fouling something up? He said that its what plumbers use when Liquid Plumber doesn't work. Any further suggestions would be very helpful.
  • campbell_jac Dec 15, 2009
    How do I fix this problem? I only know basic plumbing repair. Can you provide me with advice on how to get rid of the air lock problem?
    New Friend:
First of all plumbers(at-least none that Ive EVER known ) would attempt to use any type of liquid drain cleaner/unclogger but having said that I did have the same problem and here is how I fixed it most tubs have what they call an over flow drain it is the round metal/chrome/brass thing that is on the bath tub under the faucet it usually has two flat head screws one on each side I took that off and the straightened out a metal coat hanger(as best as i could ) and tried to leave a little hook at the end then i put that end(hook-end) down the hole where the overflow cover was at (be aggressive/push/jiggle/twist/cram/...ect..wharever you call it) and you just might be surprised (I was) I pulled out ALOT of yucky Stuff..hair/goop..and whatever else that was(GROSS) anyway drain works fine now.replace the cover make sure that the side that has the cut out/hole is on the bottom when you put the cover back on (That's where the water goes in if the tub is overflowing(*before it actually overflows the water tries to run under/over that and down the drain)Now my drain drains faster than it did when I moved in here.Hope this helps you
Posted on Dec 21, 2009
    President:
  • 1,378 Answers
Run a short snake thru the line. Somewhere between the drain and the tee into the line with the sink is a clog.
Posted on Dec 09, 2009
  • 1 more comment
  • John Prohaska
    John Prohaska Dec 09, 2009
    I forgot to add...sometimes using a plunger is enough to manually move the clog out of the drain line...try that first since you won't even need to pull to drain plug to do it.
  • John Prohaska
    John Prohaska Dec 10, 2009
    If you run the sink for several minutes it never backs up? If not, how can it be your main line? If your sink is working then it should be safe to assume the vent and drain are fine and the trouble is in your trap or overflow drain of the tub. If the overflow is blocked you could have an air lock building in your tub line everytime the water starts to fill up.
    I would not use acid...no plumber I know uses liquid plumber or acid at all. Every one (I deal with several in my job) uses a snake through various cleanouts to remove any blockage.
  • John Prohaska
    John Prohaska Dec 15, 2009
    If you run the sink for several minutes does it back up as well?
    If it does the vent to atmosphere is plugged. You could get on the roof and look through the pipe that riswes out of the area where the tub is. You likely find a bird or squirrel blocking the line.
    If the sink is ok you want to disassemble the drain and look for damage or simply replace the stopper assembly. The linkage might be bad allowing the stop to sit low and slow down the draining or else that area is clogged and needs to be cleaned. Remove the lever you use to plug the tub and the stop and linkage will pull up and out of that opening for inspection.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
1.Please keep hair dry and neatly groomed before using.
2.Insert the plug into proper the socket.
3.Turn it on and adjust the temperature, you can use when the temperature reach what you want.
4.In the process of using, one hand pulls hair end and comb with straighter.
5.If you want to keeps straight hair last longer, please use hair styling lotion and softener lotion and wash clean before hair straightening.
6.It should not clip too much hair, if you want to clip more hair, you should be slow down the speed in the process of drawing.
7.It will be turned off by an hour automatically, turn it on when you use against.
Chornic Hair Straightener Brush Instant Magic Silky Straight Hair Styling...
Posted on Dec 16, 2016
SOURCE:
Drop in bathtub
people like to enjoy long, hot soak in a bathtub after a long day after work, having a proper bathtub is a must. When it comes to choosing what type of bathtub you would like, there are multiple things you need to consider.
If you have a smaller sized bathroom,
A Drop - in tub will most likely be more beneficial for space saving.
  • Drop - in bathtubs are usually lower priced .
  • You can easily have a shower head without extra plumbing hassles.
  • A drop - in tub allows you more space in your bathroom.
  • Designed with lower sides making getting in and out easier.
  • Can be fully enclosed with minimal construction.
  • Easier installation if you want a whirlpool tub.
  • Typically easier for bathing small children.
The choice of having a bathtub reflects your consciousness towards your bathroom and precise health.
And when it comes to Drop in bathtubs,
"The American Standard Evolution Bathtub"
is entirely different, universal and better fits for your bathroom.Having 21.5 inches in depth, this bathtub allows you to enjoy at least 3 inches deeper soaking bath in this bathtub. The drainage system is quick and even. American Standard Evolution Bathtub has reversible drain outlet which cleans water fast.
Read the full review to get a holistic overview including features ,specification,pros and cons.
hydro-systems-customized-bathtubs-hydrosystems-with-drop-in-bathtub-relaxation-drop-in-bathtub-nvu2yxrtj1tcjm5kl0oggpyr-5-0.jpg
May 11, 2016 | Home
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Mar 09, 2014 | Jacuzzi - Bathtub - Alcove - Navona -...
LADBS Plumbing inspector says we need a temperature regulator for an In-Wall Lavatory Kit in a tub. The tub does not have a shower nor a wand? Which section of the code indicates this?
2010 International Plumbing Code
414.5 Limitation of Hot Water in Bathtubs and Whirlpool Bathtubs.
418.0 Shower and Tub-Shower Combination Control Valves.
Feb 28, 2013 | Newport Brass 1500 SERIES IN WALL LAVATORY...
I need to pump out a large tub in my basement to my drain because my drain is 8 feet off the floor. do you know where I can buy this pump or what it is called thanks jimmy and susan
you need to get a pump that will push water about 10 feet. sump pump is probably what I would use. Sears usually carries pumps like that as well as Steve Regan Company.
Dec 18, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Bathtub takes 3 mins to start draining. The drain is not clogged. After about 4'' of water the tub starts to drain and drains fast, but won't even attempt to drain until about 4'' full. Same thing...
Might be the problem, especially when you can't get to those pipes, always use 2 inch. If you had a vent problem, the water would gurgle out very slow, and the toilet wouldn't flush. The 2 inch trap at the tub is a must, it will never clog, and you shouldn't have to worry about it. I'm surprised that they built it that way. Most drain lines are 3 inch with a vent at the farthest point, so all the smaller lines would be 2 inch all the way to the roof except for the p-traps at the sinks. Hope this helps.
May 01, 2010 | Home
Bath tub leaks
Well if its not from drain then it could be from one of the supply valve (hot/cold) it is also possible that its leaking from the overflow drain. this gets overlooked sometimes because of its location. One thinks that water has to be filled that high but one might be surprised how much water gets there when taking a shower or splashing in the tub. There should be an access panel to check the valves and overflow gasket. If not remove the handles and echuns to see if you can see anything.
Mar 31, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Slow draining tub.
You need to run a snake through the overflow. I'm sure there is hair that is caught in it. You remove the overflow cover. The p-trap is just about 8 to 12 inches below. There isn't a need to go any further but it doesn't hurt.
Mar 21, 2009 | Maax Shower Drain 10000041-105
Home Logo
2,795 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
