J700 - Just one question! How do I set up the Voicemail? Cheers
First you'll want to verify that you have set up voicemail with your current service provider. If you've already taken that step, the phone is actually pre-programmed with a quick key to get into your voice mail box.
Press and hold down the 1 key, this will bring you to your voicemail, if this is the first time you're accessing it, you'll have a default password of either 1111 or 9999. Try either of those and it will then ask you to set up your new password, follow the voice command instructions and you should be on your way!
If neither of those passwords work, I would recommend calling your service provider and making sure that they don't use a different set of generic passwords.
Or if pressing and holding down the one key doesn't work for you, simply dial your own 10 digit number, and when you hear the voice telling you to leave a voicemail, press the * key and it will begin the login process as discussed above.
Hope this helps!
