Hitachi 61SWX10B 61" Rear Projection Television Logo
Posted on Apr 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hello there, We bought our Hitachi hd tv less than 2 years ago . Last night whilst watching the tv, the picture suddenly went blurred, almost like 3d with the red, blue and green not lined up in the images on screen, the screen then went very dark, you can still see the images but behind a very dark blue screen and the images are still red, blue and green merged images.It is totally unwatchable now :( What do you think this could be and is it fixable? The model is a Hitachi L32HO1UA HD TV . I would be grateful for any help or suggestions.
Kind regards
ellie
Piotr Pachkaev
Level 3:
Master:
  • Hitachi Master 306 Answers
  • Posted on Apr 26, 2017
Piotr Pachkaev
Hitachi Master
Level 3:
Master:
Answers
306
Questions
Helped
106553
Points
1533
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 05, 2007
SOURCE: Hitachi HD projection TV-red and green wave and alignment problem
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Anonymous
  • 232 Answers
  • Posted on Dec 28, 2007
SOURCE: HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Anonymous
  • 579 Answers
  • Posted on Feb 15, 2008
SOURCE: Hitachi 51SWX20B's screen has 3d effect
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Anonymous
  • 4234 Answers
  • Posted on Apr 03, 2008
SOURCE: hitachi ultrascan HD pic looks like a 3D movie w/o the glasses
You have a problem with teh convergence circuits. This can be caused either by defective convegence ICs or even bad connections at the pins of these ICs. I would first resolder the pins on the ICs. If that fails, replace them. That should resolve the problem. These ICs are large and black, attached to a heatsink and are marked STKxxx. There should be 2 of them.
Dan
Anonymous
  • 41 Answers
  • Posted on Apr 16, 2009
SOURCE: the Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
1helpful
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
2answers
Pic suddenly went dark, very dark. Images seen are oversaturated. hitachi ultrascan hd is about 8 years old. Help!
I have the same problem. I took the back cover off of the TV and blew all of the dust out and the TV started working again. But this only lasted 2 days. Now the TV is dark again.
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
1helpful
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
No power to my Hitachi 42hdm12
Hi, If even trying the TV in another known good outlet, it still doesn't work, do a hard/full reset - turned off via master power or unplug for a couple of hours. If all else fails, maybe you should seek the services of a qualified professional since this involves opening the unit, circuitry diagnosing and board/component repair/replacement. Hope this be of some help/idea.Post back how things are or should you need further information. Good luck and kind regards.
Surround Sound Installation
The Hitachi 50UX57B is a 50 inch standard projection TV with a standard screen. It is not HD ready. If you need it, I think I can download the owner's manual (in PDF format) from Hitachi and foward it to you.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
