Our two left speakers front and rear will not work. The two right speakers and center channel do work.....We have hooked up the microphone and all speakers work...
If the last advice did not make sense, change the wire connections to the opposite side speakers. This will confirm the speakers are good and either an adjustment must be made on your settings or you have lost a channel on the amp
Check the connection on the back of the receiver. Check the balance setting, make sure that it's in the middle. Try another mode like stereo, you should hear left and right front only. Also, if your receiver has an on screen menu, check the dB levels for the front and rear left speakers. Good luck!
