Turn on the tv, then push the code search button and the tv button on the controller. start pushing the power button unilt the set turns off. immediatly hit the enter button. You have to hit the enter button immediatly after the set goes off.you might have to do this a few times because it is easy to push the power button a split second after the set turns off! you know it worked when you push power and the tv works
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
