If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Hi, Certainly the grooves are not cosmetic. These are meant for removing the back plate for which there is a special tool to turn it anti-clock wise to open.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
After replacing battery watch should be reset! Short the 2 contacts that are next to each other on the board, using a metal object. This is very safe!!!. Now you can set watch.
mcdevito75 here, Rado a great watch and with a $50.00 band, at least. BEST BET, look for a small watch repair shop in your area for this band adjustment. Links are held in by special pins and a link remover tool is need to remove these links.
You are right - there is the procedure to follow. First - you have to align the groove for stem. Second - a lot of pressure. I doubt you can do it without a special case back closing tool. If you are not successful, there is no other way, but to ask for help at your nearest watch repair shop.
Here's my suggestion. Take it to the jewelry dept at Walmart. Do you have one where you live. They'll replace for free - Battery $8 Watch how they do it with their tools and you'll know how to do it yourself in the future. Good luck
