Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors. Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle). Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Right click on the desktop in a clear area and scroll down to either resolution or properties. From this you can experiment with resolution settings to see which setting best fits your display. After each setting change the computer will ask you if you want to accept the changes, it will give you 15 seconds for each change.
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
You need to check that display resolution in your Display properties is set to the native resolution for wide monitor typically 1440><900 for the size you mention.
Blurred image is due to using 4 : 3 resolution setting of 1024 >< 768 on a 16 : 9 wide monitor.
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
