There is what seams to be a sealed plastic ring on the top of the stainless drum is there suppose to be liquid in it there is a liquid in there I wonder is that whats making it off balance washer spins of balance I had to replace the top bearing on the "drive shaft" it was making alot of noise the cluth assembly seamed ok but still kicks out on spin cycle
Stpnlok,
Did you follow my post at this link Clutch repair post for your repair ?
I’m a little confused by this description “”there is what seams to be a sealed plastic ring on the top of the stainless drum is there suppose to be liquid in it there is a liquid in there””.
Maybe go to searspartsdirect.com and look at the exploded view and give me a p/n.
“”I had to replace the top bearing on the "drive shaft" it was making alot of noise the cluth assembly seamed ok but still kicks out on spin cycle””
Are you saying you replaced the upper One-Way Roller clutch bearing assembly only? If so that tells me you purchased the whole clutch assembly. I know of no parts supplier that sells the upper One-Way Roller clutch bearing assembly alone. We Are talking about a FAV6800A machine correct? To make sure I’m following here is the clutch parts view.
Here is pic of the same clutch causing dC errors prior to clean up.
Upper One-Way Roller clutch bearing
Is this the part you speak of ""I had to replace the top bearing on the "drive shaft" it was making alot of noise the cluth assembly seamed ok but still kicks out on spin cycle""
If we are talking about a FAV6800A or FAV9800A I can help you.
Let me know....Rich
