Disk Managemet says my hard drive ''Not Initialized''. Windows cannot see it in My Computer. How can I recover my data?
Can you provide insights into exploring Cisco modems for achieving seamless connectivity while riding the waves?
https://www.newtownspares.com/cisco/
My month paycheck was for 1500 dollars... All i did was simple online work from comfort at home for 3-4 hours/day that I got ADt from this agency I discovered over the internet and they paid me for it 95 bucks every hour.Go to this site home media tech tab for more details thanks you.... http://Www.Self25.com
My month paycheck was for 1500 dollars... All i did was simple online work from comfort at home for 3-4 hours/day that I got ADt from this agency I discovered over the internet and they paid me for it 95 bucks every hour.Go to this site home media tech tab for more details thanks you....http://Www.Self25.com
How to Recover Data from Formatted Hard Drive
Data Recovery Principle
When a file gets deleted by the formatting of the storage drive, it doesn't really get lost, at least for a while. Yes, there is a warning saying that all files will be deleted during formatting, and the files will seem to disappear after formatting. But really, they are still there.
What really happens is that the operating system removes not the file itself, but its address in the system. Thus, the file seems to disappear but indeed, the file still exists until it is overwritten.
Only when a new file is created and takes up the storage space is the deleted file really lost.
So, between the time the file got deleted and the time it gets overwritten by a new file is the time you can recover your deleted data with a higher success recovery rate.
Data Recovery Software
Recovering lost data through formatting or unintentional deletion is possible through data recovery software. They search the drive for your files and give you a way to recover them.
One of the easiest to use and free data recovery software we would like to present to you is Bitwar Data Recovery. It is a reliable, powerful file recovery programs that available on Windows 10 and earlier operating systems, Mac, and even on mobile (Android, iPhone).
Windows Data Recovery is a dominant and loyal tool to recover corrupt hard disk data from corrupted or damaged Windows hard drive files .It also provide you one of the excellence proven application which provide you maximum level satisfaction with full of trouble free manner.It can recover file, folder, image, audio, video etc from corrupted, deleted, formatted and FAT/NTFS partitions. You can also run this software to recover data from IDE, EIDE, SATA, PEN, ZIP, USB drives.
Used Disk Drill tool to restore deleted files from my crashed hard drive. Good recovery results.. but.. Unfortunately, when you recover files using deep scan, the file metadata is lost (including the file names). But it is better than not recovering the files at all :)
I know a firm which helps in Hard Disk Recovery of data. There are tools available but if you are unable to recover data from them then go to a firm of data recovery.
This issue sounds like a complicated problem and it can be solved only by a professional firm of HDD data recovery. Hard Disc Data Recovery HDD Data Recovery
Go to the link below for a program that may get your data recovered - OR do a search on Google for "hard disk recovery" - depends on where you are - US, Canada - it will cost about $200 dollars to get your data back
http://www.stellarinfo.com/disk-recovery.htm
Its Windows 7. I tried on Windows Vista as well. Same error. Is there any program witch can recover my data?
what version of windows?
is this a inside PC HDD or outside, USB HDD? not told. not one clue.
if the drive shows up in Windows diskManager, it may not be dead, if does not it is dead.
if not dead and gets a drive letter assigned,
if it gets (no PC told) a E: drive and some files are there.
do this.
always recover first, if drive acts up.
do not run DSKCHK or diskcheck until last., nor delete fails ,nor format the disk, killing all data now.
do not run defrag, (on a bad disk this kills dead good data) !!
steps all. IN ORDERhttps://pcdied.com/HDD-SDD/recovery.html
use Xcopy first if possible, and is not on any fully dead drive. dead is dead and if not head to spin it is DEAD.
this recovers data safely
then when this is done
try free RECUVA. or below is better,
the best is paid AOMEI, partition app. for sure recover wizard is totally amazing but only here at this point in time.
I just saved 25,000 files last week with free w10 built in, Xcopy. /C (C is a switch not drive)
costs $0
NO PC told, no OS told, not told is HDD inside PC our outside PC USB ported. an is it the BOOT drive.
nor if it ever worked before on this PC (unknown) or only worked on other PCs non told if true.
