When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted. With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk". Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
Iv had this go to your Archos and do RECOVERY Then go to your computer load the Archos programe. Go to you archos account and find the updates for your Archos. Right click and SAVE TO YOUR COMPUTER NAME IT Archos 1..Do the same with the secound and third Updates if there are anymore.
Now you will need to see your Saved program which should be on your desktop and your Archos in your MY COMPUTER Reduce both these so you can see them .
Nearly there
Go to my computer Drag and drop the First programe Archos 1 onto the Archos in My Computer Go to your Archos and click OK
THIS WILL TAKE UP TO 3 - 4 MINS TO DOWNLOAD
gOOD lUCK
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
I think it means 'File system FAT error'. Use the solution above by IPOD tech for reformatting the hard disk. It should be OK. I used the solution to reformat my archos7 last night, and it is working fine.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
go to archos firmware and download version 2.1.04 to your pc or laptop and save it in a folder then get ur mp4 turn it on and go format you will get a screen that says done leave it on that and connect to your pc or laptop it will recognise your mp4 then go in my computer and open 405 and open your save file and drag the save file into the 405 but NOT into a folder below them and after it has\copied turn the 405 off and start it up should be as good as new
hi!
go to archos.com click on downloads then click on firmware and follow the instuctions !! =].. i had the same problem!! all my music got deleted but it works again !!!
have you tried resetting the machine on the bottom their is a tiny hole put a reasonable sized safety pin through that you use for a babys nappy.I found this reset my archos!!!!
