Nokia 6070 Cellular Phone Logo
Anonymous Posted on Dec 08, 2009
What does the headset symbol on a nokia 6070 screen mean? I can make calls but the line goes dead after the connection is made
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
814
Points
13
It means that there must be a head phone or something still inserted in your phone. the line goes dead because the phone thinks that head phones are in and transfer it throught the head phones
6070 head phone symbol problem
Good day!
if the problem of your c.p is always appear a headset icon on your phone even doesn't?
so your problem is the P.I. the parts that connecting to your head set it is replaceable or you can spray it with the contact cleaner to clean the contact..
thank you for using fixya..
6helpful
6070 Headset symbol issue i have a Nokia 6070 and
If you still have the headset, connect it to the headset connector and remove it, do this several times and check everytime you disconnect it. If this doesn't help, please check if there's any short on the headset interface. Clean it with a soft cloth or cotton dipped in alcohol or spirit.
Your last option is to open it apart and check the headset interface internally. I would recommend you to visit a mobile repairing shop and get it repaired.
Good luck..
Thanks for using FixYa.
1helpful
Sir nokia 6070 model fm not working after connecting hand set
hand set ????? headset u mean ,, headset wil work as an antenna .. so if yo headset is not fine, then it wont support
that problem can be caused by software problems and hardware problems.
At first please factory reset by scurity code. Use tool box if scurity code is not standart code. If the step not sucses, you  can chek headset conector ( you must disassembly the phone ) . chek and clean resistor and capasitor near that conector.
2helpful
2answers
it only shows when you connect a head set to your phone check wether you have connected the head set properly it mainly cause due to losse connection in the head set port
3helpful
2answers
Nokia 6070 stays in headset mode w/o headset pulled in
Try restoring factory settings which is in settings
5helpful
2answers
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen . During incoming...
Headset
this might be due to some connection prob or short circuitry occuring in the phone circuits..
try to see i fthe headset socket is clean of any metal impurities and then if there is visibly wrong outside, take it to th technician.
its not advisable to open the set ourselves
2answers
Nokia 6070
what you need to do is just for you to change your ear piece
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
